How can I change the default web interface
First of all, thanks for all of the content. They are all super helpful, but as you know, many of the containers use similar web interface ports. I currently have a Netprobe container on the docker portainer with the web interface as 3000, and when I try to install Adgaurd, it also uses port 3000. How can I change the default web interface port for my adgaurd contrainer
You would need to change the host port, as I cover in my videos. Just make sure not to change the container port.
