Immich has been updated and started from scratch.
I updated my Immich, and now it reverted to the initial setup—no photos or user registration.
Hi Waldyr_Dias and welcome.
I am sorry about this situation. Maybe not all is lost. Lets examine it.
Dokcer version of Immich (without machine learning) has 3 containers: server itself, redis cache and PostgreSQL.
My DB has volume path on Host:
/DATA/AppData/big-bear-immich/pgdata
and size is in my case 310 MB.
Upload folder for photos/vids:
/DATA/AppData/big-bear-immich/upload
size is in my case 19 GB.
So, please go here and explore Your size and content:
sudo -i
cd /DATA/AppData/big-bear-immich/pgdata
du -hs
ls -l # or mc
cd ../upload
du -hs
ls -l # or mc
I hope, that Your data are still there, just not connected to actual container instance.
Write reply about Your situation and we can continue.
I’m not exactly sure why, but I noticed the storage was full and no one had deleted my Immich. I found the files in Root/var/lib/casaos/files/appdata/big-bear-immich, so I moved the folder to DATA/AppData/big-bear-immich. After that, everything worked perfectly. I have no idea how the files ended up there, but everything is running smoothly now.
Thank you very much.
