Could you try in big-bear-casaos the Nextcloud LS?
Hello. I’m sorry for the late reply. I tried the script with big-bear-nextcloud. When i opened it with nano, it said at the bottom “[ Error reading /var/lib/casaos/apps/big-bear-nextcloud/docker-compose.yml: Permission denied ]” and the file was empty. This is the output of the script after i ran it.
utilizator@raspberrypi:~ $ bash -c "$(wget -qLO - https://raw.githubusercontent.com/bigbeartechworld/big-bear-scripts/master/edit-casaos-apps/run.sh)"
Welcome to the CasaOS App Editor.
Available apps:
big-bear-dozzle big-bear-nextcloud calibre-web jellyfin lidarr nextcloud radarr sonarr uplifting_rik
Enter the name of the app you want to edit: big-bear-nextcloud
Please select an editor:
1. nano
2. vim
Enter your choice (1 or 2): 1
environment: line 13: 471847 Segmentation fault casaos-cli app-management apply "$service_name" --file="$docker_compose_path"
Editing complete.
I also tried to manually create the folders and reinstalling big-bear-nextcloud.
PS: What do you mean by Nextcloud LS?
There is an app in BigBearCasaOS that I added so maybe I can figure out if it will work with your PI 5. It’s hard to reproduce this issue when I don’t have a Pi 5.
I’m sorry but in my CasaOS App Store there is no Nextcloud LS in my BigBearCasaOS source. I have added LinuxServer as a source and their nextcloud shows up. Here is a screenshot:
Can you try to remove the BigBearCasaOS store and re-add it?
With so many glitches happening with your system, you might think about reinstalling CasaOS, which sometimes fixes a lot of issues for people.
I tried to re-add BigBearCasaOS and it still doesn’t show up. Maybe it’s because i have LinuxServer already set as a source? Anyway, will reinstalling CasaOS remove my data?
You will need to watch the prompts and don’t delete the AppData. I would recommend a backup before running the reinstall.
You docker compose is at:
AppData is at:
/DATA/AppData/*
