I am running CasaOS 0.4.15 on a ZimaBoard.
When I try to install FileBrowser Quantum, the installer runs but returns an error message. Portainer shows that there is a running container, but the app shows “App may not be available”.
Hi @sdmorris.
Check Your container’s log. You can access it under App’s Settings:
Or better way is install & use App Dozzle.
Whatever the problem is, there is no log!
Dazzle shows “config file /mnt/Drive2/AppData/big-bear-filebrowser-quantum/data/config.yaml does not exist, please create it or set the FILEBROWSER_CONFIG environment variable to a valid config file path”
But the file does exist.
I have also set FILEBROWSER_CONFIG, but that did not help.
Maybe You have permission problem…
Uninstall all.
3 dots… Hit uninstall and mark checkbox: delete userdata
My log:
big-bear-filebrowser-quantum | 2026/04/20 18:20:26 [INFO ] A new version is available: v1.2.4-stable (current: v1.1.3-stable) big-bear-filebrowser-quantum …
Definitely 1.1.3 is working (for me). Try this version.
Search in App Store: quantum
click on it
Hover mouse cursor over blue button Install, Custom install appeared. Click Custom install.
Fill different version (tag):
And please, tell us, if it is help You.
Yes, 1.1.3 installed OK.
Previously I had tried clean installs of v1.2.4, but without success.
