Request: Add đŸȘCelestory
Hi there,
Hope you’re doing well :slight_smile:
First, I just wanted to say thank you for all the work you’re doing around BigBearCasaOS and the BigBearTechWorld ecosystem. The way you standardize and distribute apps is really valuable for people who want to build their own “mini data center” at home in a simple, efficient way.
I’d like to suggest adding Celestory to the BigBearCasaOS app store.
Celestory is a no‑code platform to create interactive experiences: games, visual novels, training scenarios, and AI‑powered chat experiences that run in the browser. The creator builds everything with a visual graph: text, images, sound, video, variables, conditions, webhooks, database connections, and, when needed, custom JavaScript. Typical use cases include training and education, communication and support.
From an infrastructure point of view, Celestory is packaged as a self‑hostable web app (Docker), which fits well with homelab, on‑prem setups and “sovereign” AI scenarios where you want full control over data and runtime.
I’ve started working on the integration using the Big Bear Universal Apps format (with app.json + a clean docker-compose.yml, without platform‑specific extensions). Here is the link:
If you have specific requirements, I’ll be happy to adjust the config to align with your standards.
Thanks a lot for your work and for considering Celestory for the store!
Thanks,
Pierre
