Updating Immich from 1.90.2 on CasaOS
I just installed Immich on my testing CasaOS, then changed the version on Docker Compose and went back into CasaOS, clicking Check, then updating, and it updated to the latest.
Should I just uninstall and reinstall a new Immich? Do you know if it is possible to not have to redo everything in Immich?
Ok, here are the options since the automatic update is not working.
Option 1
Edit the docker compose manually by copying and pasting the docker compose from the BigBearCasaOS repo and using:
Option 2
Uninstall the app and don’t delete the app data. You should also backup anything important.
Option 3
Reinstall your CasaOS.
Okay, thanks for all your help. Let me take a look at these and decide which one to proceed with.
I reinstalled CasaOS and Immich said it was up to date still at version 1.90.2 so I reinstalled just the app and it is up to date now and everything looks good. Thanks again for your help!
