Use this guide if you’re planning to use AdGuard Home as a DHCP server. AdGuard Home is a network-wide software for blocking ads and tracking. Once set up, it will cover all your home devices without needing any client-side software.
- Initial Setup:
- Go to port
3000for the initial setup. - After setup, access it via port
80.
- Run the Setup Script:
- Execute the following script to generate the AdGuard Home configuration:
bash -c "$(wget -qLO - https://raw.githubusercontent.com/bigbeartechworld/big-bear-scripts/master/generate-adguard-home-config/run.sh)"
- Restart the Container:
- After running the script, restart the container to apply the changes.
