Added Authentik to BigBearCasaOS
authentik is an open-source Identity Provider that emphasizes flexibility and versatility. It can be seamlessly integrated into existing environments to support new protocols. authentik is also a great solution for implementing sign-up, recovery, and other similar features in your application, saving you the hassle of dealing with them.
Instructions
To create the admin user, navigate to
https://[YOUR_CASAOS_IP]:9443/if/flow/initial-setup/.
When I try to access “/if/flow/initial-setup” I get this error:
If you haven’t figured out yet. Make sure to add Port 9000 as well and then use the link provided without https and port 9443. I was able to configure an account that way
http://[YOUR_CASAOS_IP]:9000/if/flow/initial-setup/.
It worked perfectly my friend, thank you very much
Hey y’all! A point of clarification for those who got tripped up on this like I did:
The period at the end of: https://[YOUR_CASAOS_IP]:9443/if/flow/initial-setup/.
MUST be included. I kept not including it because I thought it was just punctuation :laughing:
yo thanks and dear lord why’d they have design it like that!
i dont know if im posting in the right place here but i have the issue where my browser keeps eliminating the dot at the end of the address and ive tried everything but i cant get the initial setup to run
a little late but, looking around the default url, it needs the “?” to make the dot at the end work, try this:
http://[YOUR_CASAOS_IP]:9443/if/flow/initial-setup/?.
or try port 9000 if that url doesn’t work
