Added Beszel to BigBearCasaOS
A lightweight server resource monitoring hub with historical data, docker stats, and alerts.
  • Lightweight: Much smaller and less demanding than leading solutions.
  • Docker stats: CPU and memory usage history for each container.
  • Alerts: Configurable alerts for CPU, memory, and disk usage, and system status.
  • Multi-user: Each user has their own systems. Admins can share systems across users.
  • Simple: Easy setup and doesn’t require anything to be publicly available online.
  • OAuth / OIDC: Supports many OAuth2 providers. Password auth can be disabled.
  • Automatic backups: Save and restore your data to / from disk or S3-compatible storage.
  • REST API: Use your metrics in your own scripts and applications.
