Added btop to BigBearCasaOS
Description
Resource monitor that shows usage and stats for processor, memory, disks, network and processes.
C++ version and continuation of bashtop and bpytop.
Features
  • Easy to use, with a game inspired menu system.
  • Full mouse support, all buttons with a highlighted key is clickable and mouse scroll works in process list and menu boxes.
  • Fast and responsive UI with UP, DOWN keys process selection.
  • Function for showing detailed stats for selected process.
  • Ability to filter processes.
  • Easy switching between sorting options.
  • Tree view of processes.
  • Send any signal to selected process.
  • UI menu for changing all config file options.
  • Auto scaling graph for network usage.
  • Shows IO activity and speeds for disks.
  • Battery meter
  • Selectable symbols for the graphs.
  • Custom presets
  • And more…
btop software
please add the ability to change defult look to load how we want it to look like without having to every time you even refresh the page
In a new BTOP installation, it’s simply asking for a username and password. I haven’t found anything about it on Git or Google. What could be?
Hi @ibraim and welcome here!
It is:
bigbear
password
When You click on 3 dots → Settings, You can see:
