ComposeToolbox is a self-hostable web application that allows users to edit, validate, and get suggestions for your docker-compose.yml files. It has a fully featured code editor as well as a configuration panel that breaks down what exactly the compose file does.
Added by the BigBearCommunity: parkour86 (Myles Booth) · GitHub
Github
Open source and self hostable docker compose editor and configuration tool
master ← parkour86:composetoolbox
opened 08:03PM - 06 Sep 25 UTC
ComposeToolbox: Self-Hosted Docker Compose File Editor & Validator
This PR ad… ds ComposeToolbox, a self-hosted web application that allows users to edit, validate, and get suggestions for their docker-compose.yml files. ComposeToolbox features a powerful code editor and a configuration panel that visually breaks down the services and settings in your compose file. It’s designed for ease of use, making it simple to manage and troubleshoot Docker Compose setups directly from your browser.
Key Features:
Edit and validate docker-compose.yml files in a user-friendly web interface
Get intelligent suggestions and error feedback
Visual configuration panel for understanding and managing services
Persistent data storage via Docker volumes
CasaOS metadata for seamless integration
This addition follows CasaOS application standards, includes detailed metadata, and is ready for deployment on amd64 architecture.
Note:
I'm currently unsure if ComposeToolbox supports the arm64 architecture—testing or confirmation from the community would be appreciated.
@coderabbitai The app version is v1.1 but there is no image with that version. Only has a "latest" [version](ghcr.io/bluegoosemedia/composetoolbox).
