A fancy, easy-to-use and reactive self-hosted docker compose.yaml stack-oriented manager.
Features
- Manage
compose.yaml- Create/Edit/Start/Stop/Restart/Delete
- Update Docker Images
- Interactive Editor for
compose.yaml - Interactive Web Terminal
- Reactive
- Everything is just responsive. Progress (Pull/Up/Down) and terminal output are in real-time
- Easy-to-use & fancy UI
- If you love Uptime Kuma’s UI/UX, you will love this too
- Convert
docker run ...commands intocompose.yaml - File based structure
- Dockge won’t kidnap your compose files, they stored on your drive as usual. You can interact with them using normal
docker composecommands
