Added Dockpeek to BigBearCasaOS
Dockpeek is a lightweight, self-hosted Docker dashboard that allows you to view and access exposed container ports with a clean, click-to-access interface. It supports both local Docker sockets and remote hosts via socket-proxy, making it easy to manage multiple Docker environments from a single place. Additionally, Dockpeek includes built-in image update checking, so you can easily see if newer versions of your container images are available.
Key Features
  • Port Mapping Overview – Quickly see all running containers and their exposed ports.
  • Click-to-Access URLs – Open containerized web apps instantly with a single click.
  • Multi-Host Support – Manage multiple Docker hosts and sockets within one dashboard.
  • Zero Configuration – Automatically detects running containers with no setup required.
  • Image Update Checking – Monitor available updates for your container images.
Before you install, make sure to change the default credentials (SECRET_KEY, USERNAME, PASSWORD) for security.
Support
If you find this helpful, consider supporting the project:
- :teacup_without_handle: Buy me a tea on Ko-fi
Hi Dragonfire, what’s the proper way to refresh the App Store? I removed and re-added the official BigBear store, but I still don’t see Dockpeek listed. Thanks!
Hi.
I can confirm this situation. URL archive contains docpeek, but my casaOS still do not see it.
@j900 I removed the BigBear store and re-added. It didn’t seem to do anything. Then I rebooted and it showed all the new apps.
I’m guessing you have to download the new archive zip by removing and adding then rebooting to get CasaOS to reinitialize it.
Option for Passwordless Login
