Reliable and Performant File Management Desktop Sync and File Sharing Tool.
Default credentials:
Username: admin
Password: admin
Username: admin
Password: admin
default credential doesnât work.
Hi.
EDIT 10/14/2025: now admin/admin works.
Default password was not working and I spend time to search solution.
What is not working (for me):
hash password (command in container: filebrowser hash YourWord) and add username and this hashed password to config/settings.json file as two new lines.
What is working:
According to documentation of filebrowser, when You first time run it. Admin password is randomly generated and show to the docker log. It is just for one time, You must read it from here.
How to read?
On casaOS app filebrowser:
3 dots â Settings
icon âTerminal and Logsâ
tab âLogsâ
(if You see blur rainbow colored icons, You must enable Canvas permissions in Your browser- LibreWolf in my case).
FAQ:
I missed first time generated password when I run container first time, where is my password now?
You can manually delete:
/DATA/AppData/big-bear-filebrowser/
and run container again. New password will be generated.
Or in casaOS webUI click Uninstall App, checkbox: delete user data. And from AppStore install it again.
At least Tip for log viewer: Dozzle.
Votre instance est dĂ©sormais opĂ©rationnelle. Lâexplorateur de fichiers initialisera automatiquement une base de donnĂ©es contenant la configuration et les utilisateurs. Vous trouverez lâadresse IP de votre instance, ainsi que le mot de passe gĂ©nĂ©rĂ© alĂ©atoirement pour lâutilisateur admin, dans les journaux de la console. De portainer par exemple
File Browser 2.53.1 did not work with the default password of admin/admin. I had to retrieve the temporary password from the logs as indicated above. Filebrowser has as password requirements tool which checks against easily guessed passwords (even if you lower minimum password length from 12 to 1). You will never be able to change the temporary password to âadminâ. But, if you want to disable login and password altogether (which is fine for home setup with one user), go the terminal and copy the following command without quotes, âfilebrowser config set --auth.method=noauthâ
after install, open app logs, there will be your **randomly generated password
(for those who canât understand why admin/admin doesnât work)**
Thank you so much! I was wondering why the default admin/admin wasnât working. This saved me a lot of time
