Added Financial Freedom to BigBearCasaOS
:fire::fire::fire: An open source alternative to Mint, YNAB, and more. Stay on budget and build wealth without sacrificing your privacy.
Instructions
CasaOS
You need to run this script after installing.
bash -c "$(wget -qLO - https://raw.githubusercontent.com/bigbeartechworld/big-bear-scripts/master/casaos-generate-financial-freedom-app-key/run.sh)"
You can examine the script and what it’s doing here:
I recommend, no matter where the script is coming from, that you always look at it.
ZimaOS
You need to go to the app terminal.
Run
php artisan key:generate --show
Once you have the key, add it in the field below.
Then press the save button.
Screenshot 2024-01-18 at 8.30.15 AM
