Flowise AI is an Open source UI visual tool to build your customized LLM orchestration flow & AI agents. Developing LLM apps takeslength iterations. With low code approach, Flowise AI enable quick iterations to go from testing to production.
master ← add-big-bear-flowise
opened 11:41PM - 01 Oct 24 UTC
This commit adds the Flowise AI application to the BigBearCasaOS platform. Flowi… se is an open-source UI visual tool for building custom LLM orchestration flows and AI agents. The changes include:
- Adding the `docker-compose.yml` file for the Flowise application, which includes configurations for the container, environment variables, ports, and volumes.
- Adding the `config.json` file with details about the Flowise application, such as the version, image, and links.
- Adding the Flowise logo image file `logo.png`.
These changes will enable users to easily install and use the Flowise AI application within the BigBearCasaOS platform, allowing them to quickly build and iterate on their LLM applications.
## Summary by CodeRabbit
- **New Features**
- Introduced a new configuration file for the Flowise application, enhancing its metadata management.
- Added a Docker Compose configuration for the `big-bear-flowise` application, streamlining deployment and service management.
- Defined essential environment variables for application configuration and runtime behavior.
- **Documentation**
- Added CasaOS-specific metadata for improved integration and user information.
