Added Homarr V1 to BigBearCasaOS
A modern and easy-to-use dashboard. 30+ integrations. 10K+ icons built in. Authentication out of the box. No YAML, drag and drop configuration. This is V1.
Read this before installing:
IMPORTANT: This is Homarr v1.x (latest major version), which is NOT backward compatible with legacy Homarr v0.x.
Requirements:
  • You MUST generate a SECRET_ENCRYPTION_KEY (64-character hex string) using: openssl rand -hex 32
  • Data structure is different from v0.x (uses single /appdata directory)
If you have an existing Homarr v0.x installation:
  • Install this as a separate app
  • Use a different port if running both simultaneously during migration
  • Manual data migration may be required
For fresh installations, this is the recommended version.
