Kiwix Server is a .zim compatible web server: it allows you to deliver .zim files over the HTTP protocol within your local network – be it a University or your own house. Simply start Kiwix-Serve on your machine, and your content will be available for anybody through their web browser. This allows you to view a website without having internet access.
Features
Full text search engine
Search suggestions
Really small and efficient
Compatible with almost all browsers
Available on all platforms
Available as command line executable
Embedded in Kiwix UI
Able to deal with one ZIM file or XML library files
The ZIM file format is an open file format that stores wiki content for offline usage. The format is defined by the openZIM project, which also supports an Kiwix. The format is primarily used to store the contents of Wikipedia and other Wikimedia projects, including articles, full-text search indices and auxiliary files.
Ensure that your there are .zim files in the /DATA/AppData/big-bear-kiwix-serve/zim directory otherwise the server won’t launch properly and will need to be restarted
can anyone get this to work?? it keeps defaulting to an address of 172.20.0.2:8080 even after i changed the ip address and port in the casa os settings and in the terminal for kiwix yet it keeps using that address that never loads.
This IP:port is docker internal, You cannot access this port from Host, until You have setup network connection between Host and docker container as Bridge. This is how docker works (isolation).
Setup Bridge is not necessary for working! Just follow my post about 2 minutes ago in this thread.
