Added Komf to BigBearCasaOS
Komga and Kavita Metadata Fetcher is a tool that fetches metadata and thumbnails for your digital comic book library. It can automatically pick up added series and update their metadata and thumbnail. You can also manually search and identify series, or match the entire library or a series. Additionally, you can install the Komf userscript to add Komf integration directly to Komga and Kavita UI, allowing you to launch manual or automatic metadata identification.
You will need to change:
To
  • KOMF_KOMGA_BASE_URI=http://[YOUR_LAN_IP]:25600
  • KOMF_KAVITA_BASE_URI=http://[YOUR_LAN_IP]:5000
Apps
Thank you so much! This is terrific, am testing it out on my ZimaCube right now.
Thank you so much for pushing this forward. I added the right KOMF_KAVITA_API_KEY, edited the KOMF_KAVITA_BASE_URI (IP address), and left the KOMGA variables untouched (since I donā€˜t use it). Unfortunately when I want to start the application it quits after a while; since it seems to not start. Any clue why this is happening. Btw, I do use login credentials for Kavita (am using 0.8.3), although I assume this does not matter.
Since the application does not start I can pull any error-logs from the container.
Have you checked your RAM usage also check the logs.
How to install Dozzle on CasaOS using BigBearCasaOS
I have exactly the same issue. Did you found a solution? I tried also to install with ā€œcustom installā€ process. I don’t know how to retrieve logs neither.
Dozzle is nice but since the docker is not even started it cannot show logs as far as I understand (at least the container doesn’t show)
Hello, go to the settings in Dozzle and turn on stopped containers.
Wow thanks for the blazing fast support !
It gives me this error:
[main] ERROR snd.komf.app.Application -- Failed to start the app
java.nio.file.NoSuchFileException: /config/application.yml
Have I missed a step to configure?
You’re welcome; something must of changed. I don’t believe it required an application.yml. It seems to require it now, so in /DATA/AppData/big-bear-komf/config you can create an application.yml with contents:
Yes that was it, I had to follow the guide on Kavita Kavita Wiki
I’ll need to continue the setup but now at least it starts the docker container. Thank you!
Oh, nice. Thank you for solving that puzzle piece. Btw, meanwhile for a half-automated approach I am using comic-tagger which I currently run on a local machine. Although running it on KASM would be nice. GitHub - comictagger/comictagger: A multi-platform app for writing metadata to digital comics
Hello, sorry for reviving an old trend but I tried to install Komf (to use with Komga) but I’m unable to do start the app, whatever I tried, nothing work…> I did put the application.yml in the config directories and followed every instruction possible but nothing works.
Thanks in advance
