Added NPMplus to BigBearCasaOS
Docker container for managing Nginx proxy hosts with a simple, powerful interface
Default username and password. The port is 81.
Email:    [email protected]
Password: iArhP1j7p1P6TA92FA2FMbbUGYqwcYzxC4AVEe12Wbi94FY9gNN62aKyF1shrvG4NycjjX9KfmDQiwkLZH1ZDR9xMjiG2QmoHXi
Pity that you didnt add integration that comes with npmplus :wink:
Not everybody needs the integrations, as far as I know. I might make one with everything though.
Might want to check this one, has a lot of errors out of the box and password does not work.
I have been interested in using this. Would you be able to update the login creds?
Thank you. :slight_smile:
Hi @Falstaff no update of pass is possible, only remove here in forum.
Currently project (for security reason) generate new user credentials to docker log of NPMplus app.
Here is my log record after installing NPMplus:
Creating a new user: [email protected] with password: 1aaca7533ce03a3dd1c64533fa55c9d132f9d71dbe485e6a6e41d2fa6ea24b35
If You have log output empty/clean (rolled out), You can safely uninstall app with data, and install again. Use app Dozzle for easy reading Apps logs.
Thank you. This helped. :slight_smile:
