Obsidian is a note-taking app that lets you create, link, and organize your notes on your device, with hundreds of plugins and themes to customize your workflow. You can also publish your notes online, access them offline, and sync them securely with end-to-end encryption.
master ← obsidian-config-update
opened 09:34PM - 07 Sep 24 UTC
Adds the Obsidian note-taking app configuration to the Big Bear CasaOS platform.… The changes include:
- Add `config.json` file with application metadata
- Add `docker-compose.yml` file with service definition and CasaOS-specific configuration
- Provide detailed descriptions, tags, and other metadata to enhance the app's presentation in the CasaOS platform
## Summary by CodeRabbit
- **New Features**
- Introduced a configuration file for the Obsidian application, detailing its identity and versioning.
- Added a Docker Compose configuration for deploying the Obsidian app in a containerized environment, enhancing usability within the CasaOS ecosystem.
