Paperless-ngx is a community-supported open-source document management system that transforms your physical documents into a searchable online archive so you can keep, well, less paper.
master ← paperless-ngx-docker-compose-config-update
opened 09:03PM - 22 Sep 24 UTC
This commit introduces the following changes to the paperless-ngx docker-compose… setup:
- Adds CasaOS-specific configuration, including environment variables and volume mounts
- Updates the environment variables for the paperless-ngx service to include necessary configuration for the application
- Configures the Redis broker and PostgreSQL database services
The changes aim to provide a comprehensive setup for deploying the paperless-ngx application within a CasaOS environment, ensuring seamless integration and ease of deployment.
🔨 feat(paperless-ngx): add documentation tips for installation
The changes add a new `tips` section to the `paperless-ngx` service in the
`docker-compose.yml` file. This section includes a `before_install` tip
with a link to community documentation that users should read before
installing the service.
🚀 feat(paperless-ngx): Add dedicated network for services
Adds a dedicated bridge network for the paperless-ngx services to
communicate with each other. This allows for better isolation and
control over the network topology.
## Summary by CodeRabbit
- **New Features**
- Introduced a new configuration file for the `paperless-ngx` application, enhancing deployment management.
- Added a multi-container setup for the `big-bear-paperless-ngx` application, including services for document management and processing.
- **Improvements**
- Enhanced service configurations for Redis, PostgreSQL, Gotenberg, and Tika to support efficient document handling.
Change all of [YOUR_IP] to your CasaOS IP.
PAPERLESS_URL: http://[YOUR_IP]:8000
PAPERLESS_CSRF_TRUSTED_ORIGINS: http://[YOUR_IP]:8000
Username: bigbear
Password: c22e92a6-2a3d-4edf-a98e-4044834daea6
