The Pi-hole® is a DNS sinkhole that protects your devices from unwanted content without installing any client-side software. This is a fork of the Pi-hole® application that adds the ability to update the lists of blocked domains and regexes.
Update Pi-hole's lists from remote sources easily
master ← add-pihole-updatelists-docker-compose
opened 07:57PM - 18 May 25 UTC
- Added a complete docker-compose.yml for the big-bear-pihole-updatelists servic… e with environment variables, volume mounts, port mappings, and network settings.
- Integrated CasaOS-specific configuration for architecture support, metadata, and UI integration.
- Added a config.json file defining app metadata including id, version, and image for deployment and management.
- Enabled easy deployment and management of the Pi-hole fork with updated blocklist and regex list capabilities.
