Added Planka to BigBearCasaOS
The real-time kanban board for workgroups is built with React and Redux.
Requested By
Commit
Default Credentials
Username: demo Password: demo
Change Base URL
Screenshot 2024-03-18 at 11.36.12 AM
Change [YOUR_CASAOS_LAN_IP] to your CasaOS LAN IP.
Update Default Credentials
Once you get it working, you need to change the default credentials to be more secure.
Generate Secret Key
The command openssl rand -hex 64 generates 64 bytes of random data. When converted to hexadecimal format, each byte is represented by two hexadecimal characters. Therefore, the output string will be 128 characters long in hexadecimal representation, corresponding to 64 bytes of data. To clarify:
  • 64 bytes = 512 bits (since 1 byte = 8 bits)
unable to tunnel planka via cloudflared
any recomnendations on how to do that?
You need to update the BASE_URL environment variable on Planka docker. Change it to the cloudflared domain name as it is. After this you cannot access to Planka by typing local ip address.
It didn’t work, is there any other way ?
