Added Readeck to BigBearCasaOS
Readeck is a simple web application that lets you save the precious readable content of web pages you like and want to keep forever.
See it as a bookmark manager and a read later tool.
Readeck requires minimal resources:
  • 512 MB RAM
  • 200 MB storage
After installation:
  • Access Readeck at http://[IP]:8000
  • Create your first user account on initial launch
  • Configuration file is auto-generated at /DATA/AppData/big-bear-readeck/data/config.toml
Learn more: https://readeck.org/en/docs/
Cannot see it yet in the App store. Is it a matter of cache refreshing or something? Thanks again for adding it so fast!
Try to reboot your CasaOS or ZimaOS server.
It works! Wow, it is way easier to configure than Wallabag. Thanks a lot!
