Full-featured and highly configurable event-driven file transfer solution. Server protocols: SFTP, HTTP/S, FTP/S, WebDAV. Storage backends: local filesystem, encrypted local filesystem, S3 (compatible) Object Storage, Google Cloud Storage, Azure Blob Storage, and other SFTP servers.
With SFTPGo, you can leverage local and cloud storage backends for exchanging and storing files internally or with business partners using the same tools and processes you are already familiar with.
The WebAdmin UI allows you to easily create and manage your users, folders, groups, and other resources.
The WebClient UI allows end users to change their credentials, browse and manage their files in the browser, and setup two-factor authentication that works with Microsoft Authenticator, Google Authenticator, Authy, and other compatible apps.
