Added Stalwart to BigBearCasaOS
Stalwart Mail Server is an open-source mail server solution with JMAP, IMAP4, POP3, and SMTP support and a wide range of modern features. It is written in Rust and designed to be secure, fast, robust and scalable.
Key features:
  • JMAP, IMAP4, POP3 and ManageSieve server:
  • SMTP server:
    • Built-in DMARC, DKIM, SPF and ARC support for message authentication.
    • Strong transport security through DANE, MTA-STS and SMTP TLS reporting.
    • Inbound throttling and filtering with granular configuration rules, sieve scripting, MTA hooks and milter integration.
    • Distributed virtual queues with delayed delivery, priority delivery, quotas, routing rules and throttling support.
    • Envelope rewriting and message modification.
  • Built-in Spam and Phishing filter:
    • Comprehensive set of filtering rules on par with popular solutions.
    • LLM-driven spam filtering and message analysis.
    • Statistical spam classifier with automatic training capabilities.
    • DNS Blocklists (DNSBLs) checking of IP addresses, domains, and hashes.
    • Collaborative digest-based spam filtering with Pyzor.
    • Phishing protection against homographic URL attacks, sender spoofing and other techniques.
    • Trusted reply tracking to recognize and prioritize genuine e-mail replies.
    • Sender reputation monitoring by IP address, ASN, domain and email address.
    • Greylisting to temporarily defer unknown senders.
    • Spam traps to set up decoy email addresses that catch and analyze spam.
  • Flexible:
    • Pluggable storage backends with RocksDB, FoundationDB, PostgreSQL, mySQL, SQLite, S3-Compatible, Azure, Redis and ElasticSearch support.
    • Full-text search available in 17 languages.
    • Sieve scripting language with support for all registered extensions.
    • Email aliases, mailing lists, subaddressing and catch-all addresses support.
    • Automatic account configuration and discovery with autoconfig and autodiscover.
    • Multi-tenancy support with domain and tenant isolation.
    • Disk quotas per user and tenant.
  • Secure and robust:
    • Encryption at rest with S/MIME or OpenPGP.
    • Automatic TLS certificate provisioning with ACME using TLS-ALPN-01, DNS-01 or HTTP-01 challenges.
    • Automated blocking of IP addresses that attack, abuse or scan the server for exploits.
    • Rate limiting.
    • Security audited (read the report).
    • Memory safe (thanks to Rust).
  • Scalable and fault-tolerant:
    • Designed to handle growth seamlessly, from small setups to large-scale deployments.
    • Built with fault tolerance and high availability in mind, recovers from hardware or software failures with minimal operational impact.
    • Partition-tolerant failure detection, ensuring continuous operation even during network partitions or node failures.
    • Coordinator-free architecture with automatic node discovery eliminates central bottlenecks and single points of failure.
    • Kubernetes support for automated scaling and efficient container orchestration.
    • Read replicas, sharded blob storage and in-memory data stores for high performance and low latency.
  • Authentication and Authorization:
    • OpenID Connect authentication.
    • OAuth 2.0 authorization with authorization code and device authorization flows.
    • LDAP, OIDC, SQL or built-in authentication backend support.
    • Two-factor authentication with Time-based One-Time Passwords (2FA-TOTP)
    • Application passwords (App Passwords).
    • Roles and permissions.
    • Access Control Lists (ACLs).
  • Observability:
    • Logging and tracing with OpenTelemetry, journald, log files and console support.
    • Metrics with OpenTelemetry and Prometheus integration.
    • Webhooks for event-driven automation.
    • Alerts with email and webhook notifications.
    • Live tracing and metrics.
  • Web-based administration:
    • Dashboard with real-time statistics and monitoring.
    • Account, domain, group and mailing list management.
    • SMTP queue management for messages and outbound DMARC and TLS reports.
    • Report visualization interface for received DMARC, TLS-RPT and Failure (ARF) reports.
    • Configuration of every aspect of the mail server.
    • Log viewer with search and filtering capabilities.
    • Self-service portal for password reset and encryption-at-rest key management.
You’ll need to use Dozzle or go into the app settings, then logs.
Look for to sign in.
✅ Configuration file written to /opt/stalwart-mail/etc/config.toml
🔑 Your administrator account is 'admin' with password 'w95Yuiu36E'.
Here is the official guide to:
https://stalw.art/docs/install/docker/#log-in-to-the-web-interface
Run in terminal: docker logs big-bear-stalwart-mail
This will print your password.
