Added Stirling-PDF to BigBearCasaOS
Stirling-PDF is a robust, locally hosted web-based PDF manipulation tool using Docker. It enables you to carry out various operations on PDF files, including splitting, merging, converting, reorganizing, adding images, rotating, compressing, and more. This locally hosted web application has evolved to encompass a comprehensive set of features, addressing all your PDF requirements.
Stirling-PDF does not initiate any outbound calls for record-keeping or tracking purposes.
All files and PDFs exist either exclusively on the client side, reside in server memory only during task execution, or temporarily reside in a file solely for the execution of the task. Any file downloaded by the user will have been deleted from the server by that point.
Should just click on Install :slight_smile:
If you want to change the port. You would need to change the host port and then the web UI port in the app settings.
What is the standard password? I figured if I download it from the store that the user is bigbear but I can’t figure out the password nor change it
Hi @Purlaub and welcome here!
I tried it and this works - default logins:
bigbear
4500733e-a0f8-4605-a712-fd267404956a
Default logins are mentioned in yaml here.
Apps Settings in AppStore show You here (section Environment Variables):
obrazek
I see thank you! For whatever reason I thought the password is hashed. I found a way around it by deactivating the login completely. But good to know a simple copy and paste would have done it too.
Again thanks and also for all the other documentation.
