Added Unifi Network Application MongoDB 4 to BigBearCasaOS
The Unifi-network-application software is a powerful enterprise wireless software engine ideal for high-density client deployments requiring low latency and high uptime performance.
This is using 4.4.28 of MongoDB which should support Zimaboard and PI’s.
Commit
Before Install
You need to run on your host machine:
Do not run this inside the container. Do not install the Unifi Network Application before running this.
bash -c "$(wget -qLO - https://raw.githubusercontent.com/bigbeartechworld/big-bear-scripts/master/generate-unifi-network-application-init-mongo-for-casaos/run.sh)"
Instructions
Pick the app that says MongoDB 4.
I must have missed something simple.
unable to reach the unifi aplication “problem loading page” Install went as it did in the video likewise setting are identical to those in video… no obvious firewall issues.,… any thoughts?
Have you tried incognito or clearing the cache and cookies? Also, what happens when you curl the ip and port?
No joy with incognito curl curl query returns “failed to connect, connection refused”
noting obvious on the host end I can change settings but it wont connect at all.
