The Unifi-network-application software is a powerful enterprise wireless software engine ideal for high-density client deployments requiring low latency and high uptime performance.
Commit
Before Install
You need to run on your host machine:
Do not run this inside the container. Do not install the Unifi Network Application before running this.
bash -c "$(wget -qLO - https://raw.githubusercontent.com/bigbeartechworld/big-bear-scripts/master/generate-unifi-network-application-init-mongo-for-casaos/run.sh)"
