ASA Dedicated Manager tool Ark
Hey there I think having an ASA dedicated manager app would be phenomenal. I don’t believe its been made to a docker version but I could be wrong. I am pretty new to the game with Linux but this is something I know is used very heavily within the windows server world. Here is a link. Thanks!!!
Thanks for the suggestion. I did a quick look, and I don’t see there is a Docker image?
Thats probably correct. Right now everyone is running everything through terminal commands, was hoping someone here had the knowledge to push it along into a docker image.
Hey everyone,
I wanted to share the Ark Ascended Server Manager I’ve been building. It’s 100% free and designed to make running ASA servers as easy as possible, whether you’re hosting from home or spinning up multiple dedicated instances.
:high_voltage: Core Features
  • Cross-platform support
    Works on Windows and Linux (GUI with Electron, plus headless Web UI option).
  • Unlimited servers
    Run as many ASA instances as your hardware can handle.
  • One-click setup & updates
    Automatic SteamCMD integration – installs and keeps your server(s) up to date.
  • Full configuration editor
    Easily change server settings, game.ini, and gameusersettings.ini through the UI.
  • Mod management
    Install, update, and manage mods directly – no manual copying required.
  • Scheduled tasks
    Built-in support for automatic restarts, dino wipes, backups, and update checks.
  • Backup & restore
    Protect your save data with scheduled or manual backups.
  • Headless mode / Web access
    Run your servers without the desktop UI and manage everything remotely through a browser.
  • Multi-OS awareness
    • On Windows: runs native with SteamCMD
    • Linux: runs via Proton and native with SteamCMD
:shield: Why use this over others?
  • Completely free (no “pro” tier or feature locks)
  • Built for ASA, not a legacy ASE tool patched to work
  • Scales well – run 1 or 10+ servers, depending on your hardware
  • Actively being developed
Keep an eye out for Cerious - AASM
Cerious - AASM is live: GitHub - ryoucerious/cerious-aasm: Ark Ascended Server Manager
