Assigning ports in CasaOS
When installing apps on CasaOS at times it is necessary to choose ports. This is a cumbersome and time consuming operation as I have to choose ports at random. I was shut out of CasaOS after changing the port within the UI. There should be a warning generated by CasaOS if a port would not work instead of allowing a port that would brick the system. Alternatively, there should be a generator that suggests which ports to use based on those available without having tk choose at random or use the command line to figure that out.
