Boxinvy - Multi-Select
Overview
With multi select you can easily move or clone multiple boxes or items under a box of your choosing. How Boxinvy is design is Locations > Boxes > Items we wanted to be able to move boxes or items really quick incase you’re moving or just reorganizing.
Get Started
The top bar lets you know how many boxes or items you have selected. Click on this bar when you’re ready to move or clone.
Actions Tab
  • Move button: Start moving the selected boxes or items to another box.
  • Scan and Move button: Scan a box to move the selected boxes and items under it.
  • Clone button: Manually pick which box you want to clone the selected boxes and items under.
  • Scan and Clone button: Scan a box to clone the selected boxes and items under it.
  • Remove All button: Clear all the boxes and items out of this multi select.
Boxes Tab
This is all the selected boxes. You can click each box to remove it from the multi select.
Items Tab
This is all the selected items. You can click each item to remove it from the multi select.
