I have a problem, I hope you can help me. I installed a 2.5G card in my Dell Optiplex, it recognizes that the card is connected and the internet works fine, but something strange happens if I restart the server or the PC, it doesn’t work. Is there something I should do so that Casa recognizes the card correctly?
I would need more information to help you better. Are you using Windows, and are you running any virtualization software like VirtualBox? If so, have you ensured that the drivers for your 2.5G card are correctly installed both on the host operating system and within any virtual machines you’re using? Sometimes, virtualization settings can affect network card detection and functionality. Additionally, check if the network adapter is properly configured in both your OS and VirtualBox settings.
