CasaOS Jellyfin: No available plugins in catalog
Hello again!
After having had the best experience here, I’ve come to you again in the hope of solving another problem.
This time it’s about Jellyfin. I can’t view/install any plugins from the catalog. Although the official Jellyfin repository is pre-installed.
There are many others on the net who share the same problem, but none of the approaches there helped me. By the way, this is my second Jellyfin installation. Before I uninstalled it once, the catalog was working fine. But after reinstalling, no more plugins load in the tab.
I don’t know what else to do. I tried everything in my power, but unfortunately I was unsuccessful.
Once again, I am infinitely grateful for any advice.
Steps I tried out:
  • Deleted the pre-installed official Jellyfin stable repro and reinstalled it manually
  • Restarted Jellyfin afterwards
  • Still no plugins → restarted the router
  • Nothing changed → added other repos
  • Still no plugins → deleted Jellyfin and formatted the storage, where all media files was stored
  • Stopped AdGuard to check for a possible source of error and started it again → no plugins
FYI:
I do not use a VPN, which could occur a problem. I am using Jellyfin version 10.8.13, which is installed via the CasaOS app store.
I don’t know why, but it’s working again now. I unplugged both the Zimablade and the router out of frustration for about 5 minutes and now it works.
Thanks anyway!
Awesome! Glad you got it working. Sometimes rebooting things is still the thing to do! You’re welcome, and feel free to ask more questions! My goal is to build a supportive tech community!
