CasaOs static IP
Hi, how can I set a static ip for Casaos?
Thank you
You’ll need to access your router and, find the option for reserved or static, IPs, and assign an IP address outside the DHCP pool range. Then, enter the MAC address of your CasaOS server to ensure it always gets the same IP.
to solve the same problem I settled by installing a vpn like ZeroTier and so I got 2 results, the first having a fixed ip and the second having an internal lan where I have access from all Zerotier ip’s in my subnet with which to share the services exposed by CasaOS
