I was setting up my casaos and trying to setting up an app something that requires the port 80 free so I was on the casa os screen and I when to settings and change the port from 80 to 95 and then I can get it on any browser neither windows console
Can you check your IP and port with:
bash -c "$(wget -qLO - https://raw.githubusercontent.com/bigbeartechworld/big-bear-scripts/master/find-your-casaos-ip-and-port/run.sh)"
Also, when this happens, check the health of CasaOS with:
Hi; I have CasaOS installed on my Zimaboard. I changed the CasaOS port from 80 to 87 via the Settings WebUI, and now I can no longer access CasaOS. How do I fix this? I can’t even access the terminal to run the HealthCheck script
PS: I am a newbie
Go to your router and make sure the IP didn’t change. If it did, then I would recommend setting a static or reserved IP on the DHCP server.
do this
sudo ufw allow 87/tcp
sudo ufw reload
