Chrome Installation; Blank Screen Launched
I installed Chrome from the BigBear Store, and when I launch it all I get is a blank screen. Any suggestions on how to correct this?
thx
Hello, I would recommend you look at logs, then post errors if you see any:
When I try to copy/paste the errors from the Log into this reply, I keep getting an error message saying “new users can only post 2 links”. So, use this link to download it.
https://www.sendspace.com/pro/dl/w13nsx
thx
