Hi,
Is there is an app or code to use to empty the internal hard drive cache of Zimaboard ? Your help will be appreciating, Using CasaOS latest version
Hi,
I made a quick script to do this that you can run anytime:
bash -c "$(wget -qLO - https://raw.githubusercontent.com/bigbeartechworld/big-bear-scripts/master/internal-hard-drive-disk-cache-cleaner/run.sh)"
Check the source here:
thanks alot , appreciated, worked fine
Awesome, you’re welcome!
