Hi,
Would be great if Kener.ing - a full uptime monitoring system, would be added to casaos app library ![]()
Kener is a full alternative to Uptime Kuma btw
Docker compose:
# Docker Compose Configuration
# Description: This file sets up a multi-container environment for Kener (https://github.com/rajnandan1/kener).
# Last Updated: 2025-02-08
# Docker Compose Version: 3.8
# Notes: Ensure that you specify a random value for the `KENER_SECRET_KEY` environment variable before running `docker-compose up -d`.
version: '3.8'
kener:
image: rajnandan1/kener:latest # Change to 'rajnandan1/kener:alpine' for an even smaller image! 😁🚀
container_name: kener
# env_file: custom.env # Uncomment this if you are needing to export environment variables from a custom environment file. By default, Docker will import any variables that exist in `.env`
TZ: Etc/UTC
KENER_SECRET_KEY: replace_me_with_a_random_string # Keep private!! - best to define in `.env` file or through Docker Secret
# DATABASE_URL: custom_db_url # By default, a SQLite database is used - you may override the database url/type here
# RESEND_API_KEY:
# RESEND_SENDER_EMAIL:
### You most likely will NOT need to change anything below this line. Be sure you know what you're doing!! (https://kener.ing/docs/deployment/#docker-environment-variables)
# PORT: 3000 # Port that app listens on in the container
# KENER_BASE_PATH: # By default, Kener runs at `/`. You may change this to be, e.g. `/status`, etc. Do NOT add a trailing slash!! (more info here: https://kener.ing/docs/deployment/#docker-environment-variables)
# ORIGIN: http://localhost:3000
# NODE_ENV: production # This is already set to "production" by default within the container
ports:
- '3000:3000/tcp'
- data:/app/database # We suggest using a Docker named volume, which is more performant for databases
- $(pwd)/uploads:/app/uploads
# read_only: true # Uncommenting this fortifies security by marking the container's filesystem as read-only (aka no data can be written to the container's filesystem except for explicitly defined writable volumes and bind mounts, an exception has already been defined for `/database` and `/uploads`)
restart: unless-stopped
# depends_on: # <-- Uncomment if you would like to use PostgreSQL or MySQL
# - postgres # ...instead of SQLite
# - mysql #
# Only use below section if you would like to utilize PostgreSQL instead of Kener's default SQLite database. (Don't forget to set `DATABASE_URL` in `kener` service to be: `DATABASE_URL=postgresql://db_user:db_password@localhost:5432/kener_db`)
postgres:
image: postgres:alpine
container_name: postgres
POSTGRES_USER: user
POSTGRES_PASSWORD: some_super_random_secure_password # Best to define this in `.env` or via Docker Secret!!
POSTGRES_DB: kener_db
# Only use below section if you would like to utilize MySQL instead of Kener's default SQLite database. (Don't forget to set `DATABASE_URL` in `kener` service to be: `DATABASE_URL=mysql://db_user:db_password@localhost:3306/kener_db`)
mysql:
image: mariadb:11
container_name: mysql
MYSQL_USER: user
MYSQL_PASSWORD: some_super_random_secure_password # Best to define this in `.env` or via Docker Secret!!
MYSQL_DATABASE: kener_db
MYSQL_RANDOM_ROOT_PASSWORD: true
data:
