Overview
Create custom fields to adding additional information to your doors.
How to use Custom Fields
Clicking on the Custom Fields below the Admin Console category. If you do not see the Admin Console you do not have access to the Custom Fields.
- Create Custom Field: Create a new custom field in the Custom Fields form.
- Field Label: The label for the custom field.
Filter and sort the custom fields. Click on the custom field to go to actions.
- Edit: Click on the edit button to edit the custom field.
- Field Label: Change the label of the custom field.
- Field Label: This is the label of the custom field.
- Updated At: This is the date the custom field was updated.
- Created At: This is the date the custom field was created.
