Begin on the dashboard by clicking the Go Door Knocking button, which will open a map where you can begin adding doors and visits.
You can add a door to the map by clicking on it, or you can view a door by clicking on its icon.
When you click on the map, the address appears, and you may either click Yes or Cancel to confirm whether the address is correct.
When you click on an existing door, it will notify you and prompt you to add a visit.
