Hello there,
I used your tuto for installing MariaDB and Nextcloud on my Zima OS (thanks for your work !) but when I try to create the user for Nextcloud, I always have the same error :
Yes that’s exactly what I did ![]()
You can’t change the DB login details from the environment variables once it’s started, only through the DB directly.
Could you be more specific on how to do that please ?
Any answer please ? ![]()
It looks like you changed the DB credentials. Uninstall and reinstall by following the video.
