First question: Is CasaOS easy to use?
(Since English is not my first language, I used a translator to help me.)
hello.
I installed CasaOS on my Oracle Cloud instance with the help of bigbeartechworld and have been using it for almost a year now.
However, there is an inconvenience with CasaOS: docker containers that are not installed from the app store are categorized as legacy apps.
I was more of a fan of runtipi.
Now, it’s time to clean up my OCI.
I need to decide whether to use casaos, runtipi, or Xpenology.
casaos is intuitive, but I don’t want to have to migrate my other containers and
runtipi is lightweight, but the file management is a pain. a solution like NextCloud could solve the problem.
Xpenology is. Well… I’m using it on my local server, but I’m not sure if it’s suitable for OCI. I have an environment where I can create an instance identical to the main instance and test it out.
Oh my god, I forgot that Xpenology doesn’t run on arm!
What do you guys recommend?
