Last Updated: 2022-07-26
With the same bigbearaccount, you can log in to all our applications. To ensure the security of your account, we have implemented several measures, such as two-factor authentication, authentication logs, and other security methods. We also send security emails to your account whenever there is an attempted or successful login by someone else. This helps you stay aware of any unauthorized access to your account and take appropriate action to safeguard your data.
To access the security settings of your account, you can open any of our applications and scroll down to find “My Account”. Alternatively, you can access your account’s security settings directly by clicking on the link provided. From there, you can customize the security features of your account, such as password, two-factor authentication, and other security settings to keep your account secure from unauthorized access.: https://apps.bigbeartechworld.com/bigbearaccount
Change Password: The first step towards ensuring the security of your account is to change your password if needed. To make your account even more secure, you can generate a strong password using a password manager of your choice and then update your BigBearAccount password using that newly generated password. This will help you create a stronger, unique and difficult to guess password that is more secure and not easily compromised.
Two Factor: Enabling this feature requires you to use a Google Authenticator app or any other app that supports Google’s authentication two-factor timing. This means that in addition to entering your password, you will also need to enter a unique code generated by the app on your mobile device during the login process. This adds an extra layer of security to your account, as it requires someone to have physical access to your mobile device in order to log in to your account, making it more difficult for unauthorized users to gain access to your account.
Save the recovery codes when you enable two-factor authentication. These codes will help you regain access to your BigBearAccount in case you lose access to your authenticator app.
Authentication Log: This feature provides you with a history of when and where your account has been accessed by different users. By checking this history, you can easily identify any unusual login activity and take necessary action to secure your account. If you find any suspicious activity in your account access history, you can get in touch with our support team by clicking on the chat button located at the bottom right of your screen. Our support team will assist you in investigating the issue and resolving any security concerns you may have.
If you suspect unauthorized access to your account, change your password and enable two-factor authentication. Contact our support team via chat to report the issue and get help securing your account.
In order to keep your account secure, we have implemented three different methods. These include using two-factor authentication to add an extra layer of security to your account, reviewing your account access history to monitor for any unusual login activity, and updating your password using a strong, unique password generated from a password manager.
If you have any questions or concerns about the security of your account, our support team is available to assist you. You can start a chat with our support team at any time by clicking on the chat button located at the bottom right corner of our website or within any of our apps. Our team is dedicated to helping you ensure the security of your account and protecting your sensitive data.
