Unlock the power of Chrome on CasaOS effortlessly with the help of BigBearCasaOS! Follow our step-by-step guide to enhance your browsing experience. Learn how to install Chrome hassle-free today!
Hi everybody…
Have a technical question I’d like to ask?
The question is when installing and using the google chrome application on CasaOS…I don’t find any files that I have downloaded (01.mp3, 01.jpeg, 01.rar) when I log in as root to CasaOS. More precisely, the directory position of the file. I have tried several methods but still can’t find the downloaded file. What I found was that the position of the file was within the user with the kasm_user account. (/home/kasm-user/Downloads/)
What do you think I should do to check the existence of this file via CasaOS root? So I can move it into the folder directory that I like.
It seems this also applies to using other browsers via CasaOS, (firefox, opera, Brave).
Thank you again for your suggestions and input.
Good question I changed this in the new update:
Is there a way to set the time within this Kasm instance? I believe it is defaulting to UTC based on some extension automation I have set up. If not I’ll just adjust my own scheduled tasks manually. Thank you!
Hi @Allen_Davis and welcome here!
Currently I cannot try this. But, please try to add this to volumes section:
- /etc/localtime:/etc/localtime:ro
- /etc/timezone:/etc/timezone:ro
(docker-compose.yaml example) You can easily setup in App Settings on Your ZimaOS/casaOS instance, just select App, choose Settings, add these two to section volumes:
/etc/localtime /etc/localtime
/etc/timezone /etc/timezone
