Ghost is not working for me. It’s keeps crashing and not accessible.
Log from CasaOS:
big-bear-ghost | [2024-04-21 21:15:09] e[31mERRORe[39m (Code: -97)
big-bear-ghost | e[31m
big-bear-ghost | e[31m(Code: -97)e[39m
big-bear-ghost |
big-bear-ghost | e[37m"There was an error starting your server."e[39m
big-bear-ghost | e[33m"Please use the error code above to search for a solution."e[39m
big-bear-ghost |
big-bear-ghost | e[1me[37mError ID:e[39me[22m
big-bear-ghost | e[90m3be1ef60-0024-11ef-b148-39c49c1d0847e[39m
big-bear-ghost |
big-bear-ghost | e[90m----------------------------------------e[39m
big-bear-ghost |
big-bear-ghost | e[90mInternalServerError: (Code: -97)
big-bear-ghost | at Server. (/var/lib/ghost/versions/5.82.2/core/server/GhostServer.js:96:34)
big-bear-ghost | at Server.emit (node:events:517:28)
big-bear-ghost | at emitErrorNT (node:net:1844:8)
big-bear-ghost | at process.processTicksAndRejections (node:internal/process/task_queues:82:21)e[39m
big-bear-ghost | e[39m
big-bear-ghost | [2024-04-21 21:15:09] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:15:09] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:15:09] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:15:09] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:15:14] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m3e906d90-0024-11ef-895b-2b4ab6f8d7d3e[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | [2024-04-21 21:15:14] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:15:14] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:15:14] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:15:14] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:15:17] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m40d24740-0024-11ef-8ec7-2f52402a1b8ee[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | [2024-04-21 21:15:17] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:15:17] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:15:17] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:15:17] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:15:22] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m43bae840-0024-11ef-9a91-f95c3539cf2fe[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | [2024-04-21 21:15:22] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:15:22] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:15:22] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:15:22] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:15:26] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m462ece70-0024-11ef-b01a-bf6b1b91ca21e[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | [2024-04-21 21:15:26] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:15:26] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:15:26] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:15:26] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:15:31] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m48e6c280-0024-11ef-b5b7-df93533c188ce[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost-db | 2024-04-21 21:15:05+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.36-1.el8 started.
big-bear-ghost-db | 2024-04-21 21:15:06+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
big-bear-ghost-db | 2024-04-21 21:15:06+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.36-1.el8 started.
big-bear-ghost-db | 2024-04-21 21:15:06+00:00 [Note] [Entrypoint]: Initializing database files
big-bear-ghost-db | 2024-04-21T21:15:06.766547Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
big-bear-ghost-db | 2024-04-21T21:15:06.767772Z 0 [System] [MY-013169] [Server] /usr/sbin/mysqld (mysqld 8.0.36) initializing of server in progress as process 79
big-bear-ghost-db | 2024-04-21T21:15:06.814573Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
big-bear-ghost-db | 2024-04-21T21:15:08.457005Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
big-bear-ghost-db | 2024-04-21T21:15:12.204060Z 6 [Warning] [MY-010453] [Server] root@localhost is created with an empty password ! Please consider switching off the --initialize-insecure option.
big-bear-ghost-db | 2024-04-21 21:15:18+00:00 [Note] [Entrypoint]: Database files initialized
big-bear-ghost-db | 2024-04-21 21:15:18+00:00 [Note] [Entrypoint]: Starting temporary server
big-bear-ghost-db | 2024-04-21T21:15:18.901293Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
big-bear-ghost-db | 2024-04-21T21:15:18.905113Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.36) starting as process 121
big-bear-ghost-db | 2024-04-21T21:15:18.985891Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
big-bear-ghost-db | 2024-04-21T21:15:19.425698Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
big-bear-ghost-db | 2024-04-21T21:15:19.982725Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
big-bear-ghost-db | 2024-04-21T21:15:19.982788Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
big-bear-ghost-db | 2024-04-21T21:15:20.009994Z 0 [Warning] [MY-011810] [Server] Insecure configuration for --pid-file: Location '/var/run/mysqld' in the path is accessible to all OS users. Consider choosing a different directory.
big-bear-ghost-db | 2024-04-21T21:15:20.050610Z 0 [System] [MY-010931] [Server] /usr/sbin/mysqld: ready for connections. Version: '8.0.36' socket: '/var/run/mysqld/mysqld.sock' port: 0 MySQL Community Server - GPL.
big-bear-ghost-db | 2024-04-21T21:15:20.050801Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Socket: /var/run/mysqld/mysqlx.sock
big-bear-ghost-db | 2024-04-21 21:15:20+00:00 [Note] [Entrypoint]: Temporary server started.
big-bear-ghost-db | '/var/lib/mysql/mysql.sock' -> '/var/run/mysqld/mysqld.sock'
big-bear-ghost-db | Warning: Unable to load '/usr/share/zoneinfo/iso3166.tab' as time zone. Skipping it.
big-bear-ghost-db | Warning: Unable to load '/usr/share/zoneinfo/leap-seconds.list' as time zone. Skipping it.
big-bear-ghost-db | Warning: Unable to load '/usr/share/zoneinfo/leapseconds' as time zone. Skipping it.
big-bear-ghost-db | Warning: Unable to load '/usr/share/zoneinfo/tzdata.zi' as time zone. Skipping it.
big-bear-ghost-db | Warning: Unable to load '/usr/share/zoneinfo/zone.tab' as time zone. Skipping it.
big-bear-ghost-db | Warning: Unable to load '/usr/share/zoneinfo/zone1970.tab' as time zone. Skipping it.
big-bear-ghost-db | 2024-04-21 21:15:25+00:00 [Note] [Entrypoint]: Creating database ghost
big-bear-ghost-db | 2024-04-21 21:15:25+00:00 [Note] [Entrypoint]: Creating user ghost
big-bear-ghost-db | 2024-04-21 21:15:25+00:00 [Note] [Entrypoint]: Giving user ghost access to schema ghost
big-bear-ghost-db |
big-bear-ghost-db | 2024-04-21 21:15:25+00:00 [Note] [Entrypoint]: Stopping temporary server
big-bear-ghost-db | 2024-04-21T21:15:25.656697Z 13 [System] [MY-013172] [Server] Received SHUTDOWN from user root. Shutting down mysqld (Version: 8.0.36).
big-bear-ghost-db | 2024-04-21T21:15:28.184078Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.36) MySQL Community Server - GPL.
big-bear-ghost-db | 2024-04-21 21:15:28+00:00 [Note] [Entrypoint]: Temporary server stopped
big-bear-ghost-db |
big-bear-ghost-db | 2024-04-21 21:15:28+00:00 [Note] [Entrypoint]: MySQL init process done. Ready for start up.
big-bear-ghost-db |
big-bear-ghost-db | 2024-04-21T21:15:29.068237Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
big-bear-ghost-db | 2024-04-21T21:15:29.071335Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.36) starting as process 1
big-bear-ghost-db | 2024-04-21T21:15:29.084850Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
big-bear-ghost-db | 2024-04-21T21:15:29.435230Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
big-bear-ghost-db | 2024-04-21T21:15:29.874021Z 0 [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
big-bear-ghost-db | 2024-04-21T21:15:29.874087Z 0 [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
big-bear-ghost-db | 2024-04-21T21:15:29.905654Z 0 [Warning] [MY-011810] [Server] Insecure configuration for --pid-file: Location '/var/run/mysqld' in the path is accessible to all OS users. Consider choosing a different directory.
big-bear-ghost-db | 2024-04-21T21:15:30.007380Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Bind-address: '0.0.0.0' port: 33060, socket: /var/run/mysqld/mysqlx.sock
big-bear-ghost-db | 2024-04-21T21:15:30.007913Z 0 [System] [MY-010931] [Server] /usr/sbin/mysqld: ready for connections. Version: '8.0.36' socket: '/var/run/mysqld/mysqld.sock' port: 3306 MySQL Community Server - GPL.
big-bear-ghost | [2024-04-21 21:15:31] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:15:31] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:15:31] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:15:31] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:15:37] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m4c73e0e0-0024-11ef-8bd7-99a92d276f4be[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | [2024-04-21 21:15:37] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:15:37] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:15:37] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:15:37] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:15:46] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m5215fc90-0024-11ef-967d-0946f593e646e[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | [2024-04-21 21:15:46] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:15:46] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:15:46] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:15:46] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:16:02] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m5b64cc90-0024-11ef-97e2-0d836835f534e[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | [2024-04-21 21:16:02] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:16:02] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:16:02] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:16:02] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:16:30] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m6c651040-0024-11ef-851d-7fe61403ad74e[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | [2024-04-21 21:16:30] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:16:30] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:16:30] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:16:30] e[35mWARNe[39m Ghost was running for a few seconds
big-bear-ghost | [2024-04-21 21:17:25] e[31mERRORe[39m (Code: -97)
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | e[90m8cb5c4c0-0024-11ef-8ff6-eb42ef3d0279e[39m
big-bear-ghost |
big-bear-ghost |
big-bear-ghost | [2024-04-21 21:17:25] e[35mWARNe[39m Ghost is shutting down
big-bear-ghost | [2024-04-21 21:17:25] e[35mWARNe[39m Ghost has shut down
big-bear-ghost | [2024-04-21 21:17:25] e[35mWARNe[39m Your site is now offline
big-bear-ghost | [2024-04-21 21:17:25] e[35mWARNe[39m Ghost was running for a few seconds
Database Log From Portainer:
Ghost log from Portainer:
at Server.<anonymous> (/var/lib/ghost/versions/5.82.2/core/server/GhostServer.js:96:34)
[2024-04-21 21:16:02] WARN Ghost is shutting down
[2024-04-21 21:16:02] WARN Ghost has shut down
[2024-04-21 21:16:02] WARN Your site is now offline
[2024-04-21 21:16:02] WARN Ghost was running for a few seconds
[2024-04-21 21:16:30] ERROR (Code: -97)
(Code: -97)
Error ID:
[2024-04-21 21:16:30] WARN Ghost is shutting down
[2024-04-21 21:16:30] WARN Ghost has shut down
[2024-04-21 21:16:30] WARN Your site is now offline
[2024-04-21 21:16:30] WARN Ghost was running for a few seconds
[2024-04-21 21:17:25] ERROR (Code: -97)
(Code: -97)
Error ID:
[2024-04-21 21:17:25] WARN Ghost is shutting down
[2024-04-21 21:17:25] WARN Ghost has shut down
[2024-04-21 21:17:25] WARN Your site is now offline
[2024-04-21 21:17:25] WARN Ghost was running for a few seconds
[2024-04-21 21:18:27] ERROR (Code: -97)
(Code: -97)
Error ID:
b1e719b0-0024-11ef-83ad-05f4b7503585
[2024-04-21 21:18:27] WARN Ghost is shutting down
[2024-04-21 21:18:27] WARN Ghost has shut down
[2024-04-21 21:18:27] WARN Your site is now offline
[2024-04-21 21:18:27] WARN Ghost was running for a few seconds
[2024-04-21 21:19:30] ERROR (Code: -97)
(Code: -97)
Error ID:
d72a48f0-0024-11ef-be85-cf1a3c65f9e3
[2024-04-21 21:19:30] WARN Ghost is shutting down
[2024-04-21 21:19:30] WARN Ghost has shut down
[2024-04-21 21:19:30] WARN Your site is now offline
[2024-04-21 21:19:30] WARN Ghost was running for a few seconds
