Create Goal
Going to show you how to create a goal in Goalpense.
Tutorial
The first step to create a goal is to go to the Goals on the Dashboard:
This will be the same on mobile as well. You will need to click on the create goal button:
You can fill the Name, Year Goal, Tax Savings Percentage & Savings Percentage field in then click the Save button.
You have now created a goal. You can now see the goal in the Goals home.
You can now click on your goal to view it.
Update Goal
Going to show you how to update a goal in Goalpense.
Click on a goal to view it.
You will now see an Edit Goal button under Actions Box. Click it.
Now you should see Name, Year Goal, Tax Savings Percentage & Savings Percentage fields to edit. Once you’re done editing click the Save button.
Congrats you have now edited the goal!
Video
Tutorial
Delete Goal
Going to show you how to delete a goal in Goalpense.
Tutorial
You will now see a Delete Goal button under Actions Box. Click it.
Now a confirmation alert will show. Click the blue-button to confirm.
The goal has now been delete
