Help Owncloud error container big-bear-owncloud is unhealthy
I was able to install owncloud but as soon as I restart the server I get an error message container big-bear-owncloud is unhealthy. I first have to restart owncloud in Portainer then I get to the login page?
wait for the answer of this problem @BigBearClub
Hello,
I have exactly the same situation. I’m unable to install Owncloud, if though I followed the instructions to replace the CasaOS IP with my IP.
I have got a message that indicates that container is unhealthy.
I have this on my to-do list to look into.
To give additional context :
  1. I just tried to install from CasaOS AppStore OwnCloud package (big-bear)
  2. I installed it without modifying IP addresses in the container parameters:
3à I have tried to look at the Container logs (via this useful script : bash -c “$(wget -qLO - https://raw.githubusercontent.com/bigbeartechworld/big-bear-scripts/master/get-docker-logs/run.sh)”
Creating volume folders...
Creating hook folders...
Waiting for MySQL...
services are ready!
Waiting for Redis...
services are ready!
Removing custom folder...
Linking custom folder...
Removing config folder...
Linking config folder...
Writing config file...
Fixing base perms...
Fixing data perms...
Fixing hook perms...
Installing server database...
Error while trying to create admin user: An exception occurred while executing 'CREATE TABLE `oc_appconfig` (`appid` VARCHAR(32) DEFAULT '' NOT NULL, `configkey` VARCHAR(64) DEFAULT '' NOT NULL, `configvalue` LONGTEXT DEFAULT NULL, INDEX appconfig_config_key_index (`configkey`), INDEX appconfig_appid_key (`appid`), PRIMARY KEY(`appid`, `configkey`)) DEFAULT CHARACTER SET utf8mb4 COLLATE `utf8mb4_bin` ENGINE = InnoDB':
SQLSTATE[HY000]: General error: 1005 Can't create table `big_bear_owncloud`.`oc_appconfig` (errno: 13 "Permission denied")
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
services are ready!
This has been fixed:
