Hi guys, hope you can help me, is this my first post
Nice to meet you all
I have my casa os on debian 12, casa os version 0.4.15 with next cloud last version and cloudflared tunnel up and running
My issue is i have adgauardhome working with tunnel without any issue but i got the error on nextcloud about trusted domain : Please contact your administrator. If you are an administrator, edit the “trusted_domains” setting in config/config.php like the example in config.sample.php.
My config file have the following information
‘trusted_domains’ =>
array (
0 => ‘localhost’,
1 => ‘my casaos internal IP’,
2 => ‘the domain of the tunnel the complete URL like nextcloud.mydomain.com’
and don’t wotk i try to stop and start the nextcloud container same issue, what i’m doing wrong??
Can you please helpme?
Br
Thanks again man.
But i’m afraid that’s still have the same issue, i just update the debian, and reboot the server.
Also double check the config, restart the nextcloud
Same error, the domain is not in the trusted domain
Sorry, not really sure what else to try since I am not familiar with your setup. I don’t know why you keep getting the error if you are adding the domain correctly.
finally found where the CORRECT config.php file was located.looked into my container on portainer and the config is mapped to /srv/dev-disk-by-uuidXXXXX/data_new/nextcloud/config
